Data/Hora: 15 Mai 2024, 06:07
Criar Novo Tópico Responder a este Tópico  [ 11 mensagens ]
 Assunto da Mensagem: [PCM14] A.S.O.DB 2014
MensagemEnviado: 04 Ago 2014, 16:50
Simply the Best
A. Install Pro Cycling Manager 2014 + Latest Patch
B. Open Pro Cycling Manager 2014 and closed it (this will create the Pro Cycling Manager 2014 folder in your documents).
Citar:
1a. Download the A.S.O. DB 2014 Stages Pack
2a. Unpack the PCM14ASODB2014Stages.rar on your desktop.
3a. Copy the CM_Stages folder and paste (merge/overwrite) it in the folder where you have installed Pro Cycling Manager 2014 (usually C:\Program Files\Cyanide\Pro Cycling Manager - Season 2014).
Citar:
1b. Download the A.S.O. DB 2014
2b. Unpack the PCM14ASODB2014.rar on your desktop.
3b. Copy the 8 folders (from 3D to Xml) and paste (merge/overwrite) it in the folder where you have installed Pro Cycling Manager 2014 (usually C:\Program Files\Cyanide\Pro Cycling Manager - Season 2014).
4b. Copy the ASODB2014.cdb to ->
C:\Users\YourName\Documents\Pro Cycling Manager 2014\Mod\Database.
5b. Copy the top_giro.xml and top_tdf.xml to ->
C:\Users\YourName\Documents\Pro Cycling Manager 2014\Users\*YourUserName*\Import.
6b. Start Pro Cycling Manager 2014 and choose the ASODB14.cdb @ Database/Options, also check if "Rider faces" is turned on @ Graphics/Options. All other options are personal preferences, that you can customize.
UCI Teams
(click to enlarge)
WorldTour Teams
(click to enlarge)
Professional Continental Teams
(click to enlarge)
Custom Teams
(click to enlarge)
Equipment
Exclusive A.S.O.DB 2014 Equipment for all teams
(click to enlarge)
Stats
(click to enlarge)
Track Equipment
(click to enlarge)
Matrix
Stages
and many more (+2000 Stages)
Credits
OLEGTINKOV
(All files made by OlegTinkov are exclusively made for the A.S.O.DB 2014)
Wheels, Frames, Helmets, Stages, Cyclist Photos, Sponsorkits, Track Pistes, Accessoires, Mini Jerseys, Equipment Photos, Team Logos, Mini Logos, Race Logos, Staff Logos, Manager Photos, Backgrounds, Temparatures, Country Flags, Scouting Zones, Jerseys, Magazine, Autorun, Newspaper, Faces, Variants, Database, Local, Stats, Tester, Startlists and more
GRAPHICAL INPUT
(some made one jersey, others made literally hundreds of masterpieces, yet they are all heroes and need to be named)
OlegTinkov, Adams55, aidanvn13, Alludha, Alo51, altehacke, anderspcm, ANFreeman, arne_vdb, arnomoto, ataofcom, Barto72, Bavo2810, Bikefreak, Bikex, BoogieBoogie, bottecchia, brianzabike, bwiggins, ByTxT, Cancellara91, canojuancho, Cavendish-Fan, cdelpi, ContaShack, cunego111/1, cyclertom, Dahls, Daniano, Dareun, davidov, Deaddisco, denismenchov08, devnl, dn Son, Dom051, DWB, elfouc, elspartiate, Emenee, ExoiaS, felix_29, Finrod, Francisco, Fus87, Geoffrey, Geraint Thomas, Gilardino, GnrJuul, Grillo, HugoPRT568, hooliganz, home, Il Magnifico, Ivan, Jarotu, JayJunior072, Jaywol, jccavendish, jelle, Jésus de Nazareth, JMURB, jomo023, Jonaldinho59, Katusha-lotto, kev-poccl, KRCFan, kyle, LAge, laidbackmarc, Lance Armstrong 1990, Lampert, lluuiiggii, Maddrengen, Maximka, maxou44, maxteam, mcewen-vélo, Médé33, Messi, michiucf, miggi133, MolokoDrinker, MrContador, n30k, nickwillem, oentje1, Olympus, ozzie68, Pableras, Pantofola di Oro, perot, Petacchi94, Petert87, Pierre80500, pikatchuu2008, Pouhnk, Raben, rasm, raz, Ricardopcm, RicardoRmr, rjc_43, RomainM, roro_352, Sim-eraser, Sinkewitz, Sisse, Speedyfire, Stinooo, Swing59, Syrtaki, tehMalone, the manx express, TheDeksel, Thomazio, Thrige, Tourdedoping, vc_tje_vk94, VDV, Veloman06, Vino, Vlek, Will, Will007 and Zweers.
STAGES
OlegTinkov, 40leslandes, adiouk555, altehacke, Andrepg, Biggassi, Bikex, Emmea90, frunsi, Georgus, grebiere, HijoDelDiablo, Johan92, Kaimelar, KArt, Koen, Leon40, Maddrengen, Margh Norway, Mark Cavendish, marlak, Médé33, Mlakko, Natalz, Nathounet87, Nils Erik, NTTHRASH, Pellizotti2, Ricardo123, Roturn, Samuel14, SorrowLane, Sporting Nonsense, stardrummer91, Stylus, Svam, tethestar, TheManxMissile, TomC, vangelismoras96, viktorin1988, vmbw3, willxcii and xflyinghighx.
 Assunto da Mensagem: Re: [PCM14] A.S.O.DB 2014
MensagemEnviado: 04 Ago 2014, 23:33
Esta tem a equipa do Louletano?
MensagemEnviado: 04 Ago 2014, 23:35
Não
MensagemEnviado: 05 Ago 2014, 22:17
o que tem este patch de diferente?
MensagemEnviado: 05 Ago 2014, 22:39
nuno estrela Escreveu:
Não é patch é database. E o que tem de diferente de quê? :P
MensagemEnviado: 07 Ago 2014, 03:23
Um à parte: as custom teams depois podem entrar no jogo num Modo Carreira mais avançado, substituindo ou entrando com novas equipas?
MensagemEnviado: 07 Ago 2014, 22:21
esta database faz alguma coisa aos equipamentos(quadros.rodas)
MensagemEnviado: 07 Ago 2014, 22:46
Corrige os nomes
MensagemEnviado: 17 Ago 2014, 03:28
Olá!
Alguém sabe para quando a db do daily?
MensagemEnviado: 17 Ago 2014, 15:36
elyk Escreveu:
http://pcmdaily.com/forum/viewthread.ph ... d_id=36526
MensagemEnviado: 17 Ago 2014, 19:09
Olá!
padaviro Escreveu:
elyk Escreveu:
Obrigadoo ;)
